The Style Guide provides you with a set of standards for the writing and design of theme posts and pages, either for general use or for a specific publication, organization, or field.
Images
This theme supports regular image with or without caption, wide images with or without caption and full-width images with or without the caption. The examples provided below.
Concrete roads
This regular image with caption
Concrete roads
This wide image with caption
This full-width image with caption
One neat trick which you can use in Markdown to distinguish between different types of images is to add a #hash value to the end of the source URL, and then target images containing the hash with special styling. For example, to add a wider image, you need to add the #wide value to the end of the source URL.
Align Left
Fog circling above snowy mountains leading down to Iceberg lake surrounded by trees
Lorem ipsum dolor sit amet, consectetuer adipiscing elit. Morbi commodo, ipsum sed pharetra gravida, orci magna rhoncus neque, id pulvinar odio lorem non turpis. Nullam sit amet enim. Suspendisse id velit vitae ligula volutpat condimentum. Aliquam erat volutpat. Sed quis velit. Nulla facilisi. Lorem ipsum dolor sit amet, consectetur adipiscing elit. Cras pulvinar tincidunt turpis ac fringilla. Mauris eget dolor neque. Donec ac ex quis lectus sagittis vestibulum.
Align Right
Snow-covered mountains shrouded in mist and clouds
Lorem ipsum dolor sit amet, consectetuer adipiscing elit. Morbi commodo, ipsum sed pharetra gravida, orci magna rhoncus neque, id pulvinar odio lorem non turpis. Nullam sit amet enim. Suspendisse id velit vitae ligula volutpat condimentum. Aliquam erat volutpat. Sed quis velit. Nulla facilisi. Nulla libero. Lorem ipsum dolor sit amet, consectetuer adipiscing elit. Morbi commodo, ipsum sed pharetra gravida, orci magna rhoncus neque, id pulvinar odio lorem non turpis.
This is an H1
Quisque facilisis erat a dui. Nam malesuada ornare dolor. Cras gravida, diam sit amet rhoncus ornare, erat elit consectetuer erat, id egestas pede nibh eget odio. Proin tincidunt, velit vel porta elementum, magna diam molestie sapien, non aliquet massa pede eu diam. Aliquam iaculis. Fusce et ipsum et nulla tristique facilisis.
This is an H2
This is an H3
This is an H4
Quoting
“Creativity is allowing yourself to make mistakes. Design is knowing which ones to keep.” ― Scott Adams
Align Left
“Clients don’t understand their success is reliant on standing out, not fitting in.” ― Don Draper
Quotations are used for a variety of reasons: to illuminate the meaning or to support the arguments of the work in which it is being quoted, to provide direct information about the work being quoted (whether in order to discuss it, positively or negatively), to pay homage to the original work or author, to make the user of the quotation seem well-read, and/or to comply with copyright law. Quotations are also commonly printed as a means of inspiration and to invoke philosophical thoughts from the reader.
Align Right
“To create a memorable design you need to start with a thought that’s worth remembering.” ― Thomas Manss
Simple Code Block
// Simple map
var map;
function initMap() {
  map = new google.maps.Map(document.getElementById('map'), {
    center: {lat: -34.397, lng: 150.644},
    zoom: 8
Code blocks, highlighted with Prism.js
<!DOCTYPE html>
<html lang="en">
<head>
	<meta charset="utf-8" />
	<title>Prism</title>
	<link rel="stylesheet" href="style.css" />
</head>
<body>
	<header>
		<div class="intro" data-src="templates/header-main.html" data-type="text/html"></div>
		<ul id="features">
			<li>Dead simple</li>
			<li>Light as a feather</li>
			<li>Extensible</li>
		</ul>
	</header>
	<section id="features-full" class="language-markup">
		<h1>Full list of features</h1>
		<ul>
			<li><strong>Only 2KB</strong> minified & gzipped (core). Each language definition adds roughly 300-500 bytes.</li>
			<li>Very easy to extend without modifying the code, due to Prism’s <a href="#plugins">plugin architecture</a>. Multiple hooks are scattered throughout the source.</li>
			<li>Very easy to <a href="extending.html#language-definitions">define new languages</a>. Only thing you need is a good understanding of regular expressions</li>
		</ul>
	</section>
	<footer data-src="templates/footer.html" data-type="text/html"></footer>
</body>
</html>
var Token = _.Token = function(type, content, alias, matchedStr, greedy) {
	this.type = type;
	this.content = content;
	this.alias = alias;
	// Copy of the full string this token was created from
	this.length = (matchedStr || "").length|0;
	this.greedy = !!greedy;
@import url(http://fonts.googleapis.com/css?family=Arvo);
/* Styles */
body {
	font: 100%/1.5 Questrial, sans-serif;
	tab-size: 4;
	hyphens: auto;
a {
	color: inherit;
section h1 {
	font-size: 250%;
section h1,
#features li strong,
header h2,
footer p {
	font: 100% Rockwell, Arvo, serif;
Lists
Unordered Lists
The HTML <ul> element represents an unordered list of items, typically rendered as a bulleted list.
Usage notes:
  • The <ul> element is for grouping a collection of items that do not have a numerical ordering, and their order in the list is meaningless. Typically, unordered-list items are displayed with a bullet, which can be of several forms, like a dot, a circle or a squared.
  • There is no limitation to the depth and alternation of nested lists defined with the <ol> and <ul> elements.
  • The <ol> and <ul> elements both represent a list of items. They differ in that, with the <ol> element, the order is meaningful.
Ordered Lists
The HTML <ol> element represents an ordered list of items, typically rendered as a numbered list.
Usage notes:
  1. Typically, ordered-list items are displayed with a preceding numbering, which can be of any form, like numerals, letters or Romans numerals or even simple bullets.
  2. There is no limitation to the depth and alternation of nested lists defined with the <ol> and <ul> elements.
  3. The <ol> and <ul> both represent a list of items. They differ in the way that, with the <ol> element, the order is meaningful.
Footnotes
The quick brown fox1 jumped over the lazy dog2.
Footnotes are a great way to add additional contextual details when appropriate. Ghost will automatically add footnote content to the very end of your post.
Tables
Table Caption
Content categories Flow content
Permitted content An optional <caption> element;
zero or more <colgroup> elements;
an optional <thead> element;
an optional <tfoot> element;
Tag omission None, both the start tag and the end tag are mandatory
Permitted parent elements Any element that accepts flow content
Normative document HTML5, section 4.9.1 (HTML4.01, section 11.2.1)
Videos
This Mountain from Evan Mann / OWP Denver on Vimeo.
Audio
  1. Foxes are red
  2. Dogs are usually not red
